nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Sun Oct 15, 2006 7:30 pm
does your car pull when you drive it? If so how hard. I have heard of turbos comin loose from the manifold and that will make the gauge read bad, and the car will still drive, but doesnt pull as hard. So if all else fails in that arena check your immediate exhaust piping for leaks. If that doesnt work, make sure your lines are in the correct place at the throttle. I dont have pics of placement, but you should be able to find them on this forum.
As Blown 240 said. Your car should not read ) at idle. the vacuum is really is being controlled until you push the gas to open the throttle and air starts to flow with force.
