as long as you have good vacuum connections, the fuel pressure wont change at all.jb96s14 wrote:if i tap into the fpr wont that throw off the fuel press. there is another hrd vacuum line above were the hose to th w/g actuator hose is connected it has a vacuum plug on it should i tap into this line?
