Project240 »
https://forums.nicoclub.com/project240-u5974.html
Tue May 25, 2004 6:36 am
I'm pretty much clueless on how to install this boost gauge. I got it from a friend in exchange for my old KA radiator, and all I got was the gauge, no instructions or anything. I'm assuming the two wires are power and ground, so I should ground the black wire, but what should I run the white wire to?? Also, where should I tap the vacuum line for the gauge?? I saw in a couple other threads that I could T off the vacuum for the fuel pressure regulator, or maybe the BOV; what about this mystery vacuum line?? I have no clue where it goes and I have it ghetto-rigged right now with a screw plugging it up just so the car will run, can I run that vacuum line to the boost gauge??
