ca18hatch wrote:As of right now, that hose behind the throttle body is running to my purge canister. Can i just disconnect it from the canister side and hook up the gauge, or should i use a T connection?
If you've got emmissions you'll need to leave it hooked up and T off of it. If no, then just uplug it.
ca18hatch wrote:Hey float, would you recommend a mechanical or electrical gauge? Is one more accurate than the other? I was thinking about picking one up from autozone for like $40
I've got an autometer Mechanical that I've been using for about 3 years now. It works alright, but I question it's accuracy as it doesn't set at 0 anymore when the car is off.
