nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Sun Jul 09, 2006 4:38 pm
any electrical wiring on a boost gauge is more than likely for the lighting. you need to ground it,black wire, and connect the lighting to a wire connected to anything that is lit when you turn you headlamps or parking lights on. Everything else should be hoses. If this doesnt make sense go out for a drive and find someone with a fart tip...they can do it!
