Boost gauge fitting???
duffman1278
Car: 89 240sx Hatch, the wildcats!
I need to know what size fitting I need for my nylon tube off an autometer boost gauge? I've been searching around but havn't really found anything. Here's one thing I've found, will it work?
http://cgi.ebay.com/ebaymotors...ZWD1VAlso found this.http://www.beswick.com/product...d=147
Modified by duffman1278 at 8:02 AM 9/4/2007
duffman1278
This is how it is on each end right now
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Odds are it is 1/8" air line. They use a brass ferruleto pinch the line between the ferrule and a tube that slides inside the air line. You can find this at any truck parts store (think semis) and any truck stop with a service garage. You may have good luck going to an aftermarket auto parts store and bring in the gauge in case they only hire 'tards.
duffman1278
With the air line, would that allow me to hook it up to the vacuum lines?
CoupedUp
Car: 1993 Coupe
You can get them at ACE Hardware they have lots, if theyre in your area.
duffman1278
I just searched on ACE's site for "air line" and it didn't come up with anything. Is that what its called?
CoupedUp
Car: 1993 Coupe
Are you talking about the thing that goes on the end of the line that goes inside the nut of the fitting to hold it?
If so, its a little football basically with the ends cut off and a hole in it the size of the line. I dont know what its called but they have them.
duffman1278
OOO, I know what your talking about now, but I still need to know how to hook it up to a vacuum line. Would that be with the "airline?"
CoupedUp
Car: 1993 Coupe
I guess do it the opposite way, just on the other end go to a barbed fitting than put a vacuum line on it to one of the hardlines under the TB.
duffman1278
Thanks alot man, that'll work out perfectly. You think this will work?
http://www.acehardware.com/pro...72404
CoupedUp
Car: 1993 Coupe
yea sure just get the right diameters of course.
