Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Mon Jan 31, 2005 4:38 pm
I was getting pretty lazy so I finally intalled that blitz sbc id, the solenoid has been hanging out in my room in a corner for weeks. Anyways, the vacuum detect about 7.9 psi peak boost during the time it was not installed.
I installed the solenoid then cranked it to 10psi, I figured that since I am already running rich, 2 psi more won't hurt. I was going through the settings when a "gain" showed up. The manual suggest that this dictate response and is usually 5 to 15 % on stock setup so I just set it to 5%, took it for a spin and got to 9.2 psi so I guess it works...
but I still don't know what gain is and what it should set at.
