karupt93240sx »
https://forums.nicoclub.com/karupt93240sx-u209151.html
Fri Jan 16, 2015 12:47 pm
Specs : 1993 240sx KA motor super tech forged pistons and rings, 550cc injectors, walboro high volume fuel pump, top mount header, turbonetics t3/t4 bb, 38mm tial waist gate 15 lb spring, duel core alluminum radiator with duel electric fans, front mount intercooler, oil cooler, enthalpy rom ecu flash, msd blaster coil, 8mm ngk wires, bov, stock maf, ngk bkr7e gapped .28
Problem: The car has been running great for months.... one night driving home the car wont build boost in 1st or 2nd gear then third gear it will build 5-7 pounds befor cut out then 4th and 5th it will spike to 15 lbs? Then once in awhile it will turn over and not start but if i let it sit and come back 30 min later it starts up. I have changed plugs, plug wires, cap n rotor, coil, relocated the battery to trunk earlier in the year. fuel pressure stays fine and the af seem's to stay where i need it..... any ideas? im tired of waisting money and not fixing the problem!
