I just read through this thread a bit and will just interject a few thoughts.
spooled240 wrote:As for the boost, it spikes a little when the flash spool first hits but levels off and delivers a constant 10 psi now so I'm happy
If you are seeing constant boost now from changing the source of the boost gauge signal, then its likely just that the wastegate is doing what it should. But, if the source of the wastegate signal is at the compressor, then its not indicative of what is actually occuring at the manifold (which for purposes of actually making power is what is important). With yourwastegate signal at the compressor and the boost gauge signal at the manifold, if you were seeing a pressure spike and then a loss of pressure, it may be indicative of a pressure drop. What kind of intercooler are you running? It might be possible that you have a one-way boost leak (coupler). Naturally, a small pressure drop should be expected across the I/C core as airflow increases but a 2 psi variance on top of the base pressure drop (you'ld be able to check this by checking pressure at the manifold and the compressor with your boost gauge) seems kind of high.
This problem would not be apparent while you had the wastegate running off the manifold pressure as the wastegate would compensate for any pressure drops or leaks by allowing the turbo to spool more. But its certainly not ideal either way as it requires more boost at the compressor to reach a given manifold pressure with bigger pressure drops. This in turn means there is more heat in the air being compressed by the turbo. This not only results in hotter air at the TB, but can also diminish your I/C's heatsink and heat transfer capacities. Such a set up might be okay for the street, but can become problematic at the racetrack where an intercooler will see more frequent boost and longer boost durations and run into problems with heatsoak.
I would look into this regardless. If its attributed to a boost leak, then it should be an easy effective fix. But if it's an I/C problem, then of course you would have to decide if its worth the additional expense to remedy or not.
spooled240 wrote:I was reading up on different wastegate sources before and after the intercooler and from the intake manifold. It seems like tapping the intake manifold for the wastegate signal wouldn't be ideal
Reading up on this particular thread with turbo miatas, it seems like tapping the cold pipe would be ideal but tapping into the intake manifold would be dangerous. I sorta understand his concept of the throttle body leaving the wastegate closed and having the turbo spool way hard climbing a hill..but having the throttle partially closed would also limit the amount of exhaust gases spooling the turbo which in turn limits the amount of boost the turbo will create..
This is correct, but doesn't account for all of it. With some smaller turbos (relative to motor size/airflow), its possible there may be enough exhaust energy to actually pressurize the I/C piping. It won't be an extreme amount by any means, but any additional pressure will translate to more airflow passing the throttle plate. However, there are 2 feedback loops that prevent constant acceleration. They ar ethe BOV and the driver. The BOV will open to allow excess air out of the I/C pipe. The driver will likely adjust throttle position to achieve their desired level of acceleration (or constant velocity). This may actually sub-conscious involvement that could be simply detected as normal throttle adjustment. Eitherway, its definitely not something to be concerned with.
