Boost Designs turbo cams
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
I was just looking around on Boost Designs and I found the "turbo stage 2" cams. Would these produce a significant amount of power for a NA KADE, or are they called turbo cams because they are only meant to be used with a turbo set up. If anyone has any other recommendations, besides the "hot cam" swap, could you tell me? Thanks in advance.
deathkeeper
You would not want to use cams designed for a turbo application. They are designed with the goal of spooling a turbo quicker. Basically they move the powerband down the rpm range, because the turbo will provide power on the top end. For an N/A application you want to do the exact opposite to make more power. PDM Racing makes really nice cams for an N/A application.
Here are the before and after dyno charts for the PDM Stage II KA24DE Cams.
http://www.pdm-racing.com/
