bruinbear714 »
https://forums.nicoclub.com/bruinbear714-u1106.html
Tue Apr 12, 2005 5:07 pm
If I were you, I would get the ignition harness at the BARE MINIMUM. You are going to need that make full use of the emanage.
Then, if you are going to tune yourself, get a wideband and the support tool, and a laptop.
If you are going to have a shop tune, then you'll need only the support tool (unless they have the software and cable).
Depending on how knowledgeable you are, tuning yourself can be rewarding as you can make adjustments later on yourself if it is needed.
I can't even count how many times I've hooked up my laptop to the emanage in my car to make minor adjustments to fuel and timing over the last year.
