boost designs install help! already searched...
sunnys14
Car: S14
im using the boost designs stage I sticky to install my kit. the only problem in running into is the undetailed instructions of how/where to install the vacuum lines with the kit. im totally lost on the vacuum stuff. my wastegate has 2 barb fittings (one on the side and one on the top) and i dont know where and which one to use. my cold pipe has a nipple on it and i have no idea what to put on it. the BOV has to be welded on the hot pipe but what vacuum source to use? any help with these vacuum locations and pics would help GREATLY! thanks
Craving4Boost
Car: 91 240sx fastback
all your vacuum source can come from the fuel pressure regulator...it has a vacuum line that you can just T off with a T fitting and vacuum hoses...theres a picture in this forum if you dont know where that is...just type in vacuum in the search button and you should find it..fiznat posted a picture...
the wastegate has 2 ports yes...the top one you should only use if you have an electronic boost controller...if you dont you should just use the side port and T that off the fpr line as well
your cold pipe has a nipple for the hose that comes off the IACV ( idle air control valve ) it should be a perfect snug fit....its in front of your intake manifold
the BOV i reccomend to weld it onto the COLD pipe because putting it onto your hot pipe would cause to much backpressure....you know that you must weld on a flange first though right?? i think BD uses the greddy type S BOV? i forgot but you should only need to use the port that comes out sideways...that should also be T'ed off the FPR line...you can leave the other port open...it you want to use it it needs to see boost...
just to let you know...i have BD IC kit and ITS A PITA!!!....psss...direct "plug and play" my a**!! i had do a lot of s*** just to make it fit
Craving4Boost
forgot to say good luck
Nice work C4B. MUCH appreciated.
Every time I see a post like this, I'm embarassed that I backed BD.
I let you guys down once, I'll do my damnedest not to let it happen again.
smokey240sx
AZhitman wrote:Nice work C4B. MUCH appreciated.
I think we all appreciate all the contribution you did for the 240 community. ::kodak momeant::
P.S. I'll be buying the cat for BRM as soon as I figure out why I keep stalling out.
sunnys14
Car: S14
thanks alot man! if i dont have a boost controller, do i just take off the barb off the top of the wastegate? and for a boost gauge, i just tee off the fuel pressure regulator also? wow... so many tees, if that safe?
Craving4Boost
no problem at all i just want to be remember as a helpful person you guys helped me a lot so the least i can do it give back in return with what i learned...it's fun anyway
sunny...leave the port on top...just incase one day you get a electronic boots contorller (EBC)..it will be fine if you let it be though...yes i know it looks all funky with so many T's..lol but whatever works works...you acn research a little more if you want to know other places where you can T it of off...just neatness sakes
show us pictures when your done man..we'd love to see
