Boost designs charge pipes
Craving4Boost
Car: 91 240sx fastback
Does anyone have CLEAR pictures of how the charge pipes are set up on a 91-93? i wish it was labeled A B C D or something. i noticed that the charge pipe that has the BOV bung on it isn't the one to that connects to the intake manifold? but yeah pictures would help alot, thanks.
Also...Do i have to weld another 02 sensor bung on the charge pipe?
thanks guys
hannibal
Car: Red Line to Glenmont
I would like to see this also..
FYI, the 02 bung goes in the downpipe.
nissanfanatic
Car: 1992 Nissan 240sx SE
I have some. But IDK if you would think they are clear. Just posted some not too long ago so I guess they weren't. Sorry.
DammitBobby
Car: S13 91 KA24DET
Craving4Boost
hey thanks alot you saved me
Craving4Boost
I swear i saw something on the rubber "coupler" just before the intake manifold..i assumed it was a 02 sensor..sorry im a noob trying to turbo.
Also...the plastic pipe that used to connect to the intake manifold...there were about 3 hoses? what am i suppose to do with them? if you guys want me to take a picture just let me know thanks alot.
nissanfanatic
Large one on the bottom can be removed along with the box its connected to.
The second largest one is the IACV. This has to be connected to your cold pipe.
The smallest one can be plugged.
The hose running from your valve cover to the intake can be routed to your turbo intake after teh mafs or it can be left open. People run it both ways.
Craving4Boost
rseabrooke.....if you could show me onnnee moree picture of how you put that first charge pipe in (the intake manifold side) and where it's leading too that would help a lot too. thanks
DammitBobby
Car: S13 91 KA24DET
Craving4Boost
i noticed your battery isn't there....isnt it required to relocate it?
skatanic28
Car: 96 240sx
how about on a s14? thanks
DammitBobby
Car: S13 91 KA24DET
2 options one move the battery in the trunk. I had to because I have a 300 watt amp that needs a big battery. The other option is to get a smaller battery.
Craving4Boost
will it be a tight fit with a smallter battery?
