boost design turbo kit question
240sxHitman
Car: Boosted '91 240sx
I just got my car back with a new rebuilt motor in and everything seems to be running fine. now im looking at the BD stage 1. I have a Rms13 and will the BD st. 1 just bolt right up and the intercooler piping fit just right?
DammitBobby
Car: S13 91 KA24DET
The FMIC will bolt right up to the front of the car. Have to cut an angle on the bracket holding the IC. I got pics of that. The cold side IC piping needs no modifications the Hot side I had to cut one of the pipes and add a extra hose. The pignose needs a little modification to fit back on but it is no big deal. Also have to buy a mandrel bend 2 1/2 pipe to connect to the turbo for the air inlet pipe. I will take a pic of it tomorrow. I would highly recommend replacing the stock fuel pump and going with the walbro 255 and a mechanical fuel gauge. The rest of the stuff bolts right on with no problems.
Modified by rseabrooke at 2:45 PM 2/5/2005
JPG0511
Car: 1993 240sx fastback
I would like to see those pics too. I want this kit too. I asked this before but did you have to move the battery? could you take some pics of the cold sit of the piping? thanks
DammitBobby
Car: S13 91 KA24DET
Sorry a day late but will do it this morning. I misplaced my camera and found it this morning.
PalmerWMD
Car: 2004 350Z
rseabrooke wrote:Sorry a day late but will do it this morning. I misplaced my camera and found it this morning.
Looking forward to those pics!
Fred..
DammitBobby
Car: S13 91 KA24DET
Ok here are the pics. I had to clean it up some before I took the pics today.
JPG0511
where and how did you move your battery?
DammitBobby
Car: S13 91 KA24DET
Well I decided to use the 4 gauge wire that I was using for the Amp that was all ready mounted in the trunk. Were that battery was located I used a distribution block. I bought that at a car stereo shop. 1 4guage connection to the battery and 2 connections one going to the starter and 2 other connections that were smaller going somewhere. Bought plastic battery box from Wallmart for 8 bucks. Located the battery in the trunk on the drivers side. Used 4 screws and washers to hold the battery box down. Then bought a cheap plastic battery bolt down kit from autozone.
I took some pics a last year. I will try to find them and post them maybe today.
