I went to SMC’s web site (
http://www.smcenterprises.com/injector_kit.htm) and I see that they have
‘Boost Variable Speed Controller’ which ‘Automatically varies the pump speed as boost increases! This will avoid any possible "bog" from injecting too much spray too soon. Especially important on the smaller 4 cylinder cars. ($100 option)’
and ‘MAF Variable Speed Controller’ that ‘Automatically varies pump speed as airflow varies! Taps into your existing MAF sensor output signal and uses it to vary pump speed as airflow changes. Great choice for supercharged applications where boost comes in at low RPMs. Available for any car using a 0-5 volt output MAF.($100 option)’
My question it is would like to use Alcohol Injection but I want to use it as supplementary injection. That would mean that I would need the Alcohol to start spraying at 4-5psi (when the stock injectors max out). And I would like it if I could run up the boost to 15psi using just Alcohol, so I would need a Boost Dependent injection set up. What do you think about the MAF idea? What about the boost dependent idea? I just don’t know if the injection will vary enough that I’m not running super rich at 5-10psi. Do you think that I could use just this Boost Dependent Alcohol Injection for a good fuel system?
