Boost Cut
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I know a lot of you guys have already started upping the boost, or getting bigger turbos. Does the RB have a fuel cut at certain boost level? I have a Fuel cut defender for my FC3S, but I haven't seen any one mention needing one for the RB?
I would like to run 10PSI on stock RB25 turbo for now, and was wondering other than a boost controler and injectors, if anything else is really necessary.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
YES THERE IS.... ITS SET AT 14.7PSI, ALOT OF BOOST CONTROLLERS HAVE A BOOST CUT DENFENDER BUILT IN SO I THINK YOU SHOULD BE FINE.
krayton
at about 17psi the stock MAF is maxed out. so if you hit that you get a fuel cut.
....sort of wish i didnt know that :oface
rudeboy
Car: cars
that sounds like a good story. what happened?
NISMO_RB25
Thanks guys! I plan on staying at 10PSI for a while and focusing on the suspension. Big boost will come later :)
Joe
krayton wrote:at about 17psi the stock MAF is maxed out. so if you hit that you get a fuel cut.
hah me too bro...stupid wastegates...
also FYI for everyone else, a R34 MAF works like a z32's, it DOSENT max out at 17psi ;)
