float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Feb 21, 2006 10:12 am
Ok, so I recently bought a brand new S15 SR T28 SpecR turbo. It's the nice one with the Inconel exhaust blades and the built in wastegate divider. Ball Bearing, the works. This turbo is GREAT. I love it. The transient response is nearly instant, and it spools quite nicely. But I was having a pretty major problem with this new turbo, that I wasn't having with my old T25. Boost Creep. And not just a little bit. I was hitting 14psi + by redline. That's a 7+ psi creep from 4K - 7K. I didn't like it and was trying to resolve it. Now don't get me wrong, the car is REDICULOUS at 14 psi, but the power band is very non-linear, and trying not to light up the tires in first is impossible. You've got to short shift it at 3K, or only give it part throttle. So, I started tinkering around. Here was my process...
-First, I was referencing the boost for the wastegate actuator from the turbo outlet elbow. I drilled and tapped a hole and screwed a fitting it there. It works great and the vac line is all of about 3" long. But I thought that somehow this might be causing a proble, and since I wasn't running it like that on the T25 and I wasn't having problems with the T25, I moved it back over to the manifold. It didn't help and I think it actually made it worse. So I put it back like it was.
-Second, I thought that perhapse the actuator was fouled and not opening fully. So I removed it, made sure it was moving freely, and then used a tire pump and a low pressure gauge to see at what psi it was opening. Dead on 7psi.
-Third, I checked the wastegate flapper to make sure that it could freely open and close fully. No dice there either, it worked perfectly. So then I reattached the wastegate actuator, and used my tire pump again. Same deal, 7psi, and it was opening up.
-Fourth, at this point I was out of ideas. I hit up google and typed in "boost creep", or something to that effect. What I got was a bunch of DSM sites. Apparently these guys fight this alot? I guess the problem is that the opening for the internal wastegate is often too small to flow enough air for the turbo to stay at the set boost level and the turbo, ofcourse, creeps. So here was my 4th test. I unhooked the wastegate actuator arm from the wastegate flapper so that the flapper was free to move. Then I drove the car. First of all, it was totally gutless below about 4K. Coincidentally, this is the same RPM where my creep started. Only it wasn't coincidence. From 4K-7K RPM, the boost crept from about 7psi to 14psi.
Now if everything was right in the world, I should only see about 5-8psi @7K RPM with the wastegate just flapping in the wind. There is a few reasons why this happened, and I'm going to explain them so that you guys can save some of the headache that I went through.
I changed from a slightly modified SR T25 (larger compressor wheel, same housing) to an S15 Spec R T28. The SR T25 is actually a pretty decently sized turbo. The exhaust and compressor housings and blades are about the same size. This is good for effeciency. Also, for whatever reason, it looked like the opening for the wastegate in the exhaust housing was larger on the T25 than it was on my T28. The T28 is a slightly mis-matched turbo. The compressor housing and blade are noticeably larger than the exhaust housing and blades. I am also running a High Compression motor. This tends to give more exhaust and the exhaust tends to have more energy. I think those things in combination with the smaller opening on the T28 is overpowering the opening on the wastegate, not allowing enough gas to bypass the turbine blades, causing my tremendous boost creep. This also explains why it gets worse as the RPMS increase.
At this point, I now have 2 options. 1. Restrict the exhaust down so that it can't flow as much air. This will minimize the problem and is probabally the cheapest and easiest way to fix it. But IMHO, this is a bandaid, and I'll be sacrificing power and spool time. 2. Remove the turbo, AGAIN (I'm a pro at this now), and enlarge the opening for the wastegate. IIRC, there was A LOT of overlap between the opening in the housing and the flapper.
I'm hoping to perform the latter operation later this week/weekend and I'll let you guys know how well it worked. I'm anticipating this completely correcting my problem.
CLIFF NOTES: If the opening for the internal wastegate is too small, you'll get crazy boost creep, driving you nuts for at least 2/3 weeks before you finally figure it out.
I hope that my little "lecture" will save someone some time and trouble in the future.
Ryan
