IvoryJ30t wrote:i would definately suspect the replumbed dump pipe. especially if your exhaust is smaller. when you climb up in the revs, the exhaust volume increases, and could impede the flow of the wastegate gasses, causing boost creep.
IvoryJ30t wrote:you probably have the dump pipe welded to the exhaust at a 90 degree angle, causing restriction to the wastegates gas flow.
why dont you try to make the flow as smooth as possible, or use a bigger pipe for the dump.
rn240sx wrote:IvoryJ30t and Demcj:
I just wanted to thank both of u guys for your "knowledgeable" help in such a sarcastic way..!!
what the?!
I was hoping to get some replies with simple SUGGESTIONS on what i MAY have done wrong and things to do to see if that was the problem.But instead, I get the opposite..!!
the opposite? how? i suggested that you run with an open wastegate to see if it stays at 7psi. if it stays, then i suspect the 90 degree merge that your dump tube enters the downpipe. if it doesn't stay at 7psi with an open wastegate, then check your wastegate as C-Kwick suggested.
did you check it at all? if so, what were the results?
-demetrius
IvoryJ30t wrote:i know that the dump being routed into the downpipe wont cause boost creep WHEN DONE PROPERLY.
restriction- atmosphere < narrow angle entry < 90 degrees
when you have the engine flowing more and more exhaust gasses into the exhaust system as the revs climb, then you have the wastegate dump forcing more exhaust into the downpipe in an extremely turbulent manner [high angle of entry] its gonna cause a signifigant restriction of the wastegate flow.
