rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Thu Sep 30, 2004 1:14 pm
1) Yes2) Electric ones do, yes3) Boost controllers are boost controllers. The difference is: -Electric have several nice features! Different boost levels that can be changed with the turn of a dial or the push of a button. So you can have 7psi for the drive to work and in a flash jump to 14psi to kill that Z28 on the way home. Things like peak hold, scramble, and other nice data outputs is a plus, but not necessary.
Manual/Wastegate Boost controllers are set at a specific level and cannot change unless you physically change them. I have an HKS actuator about to go on because with the T25G, I can limit boost with my right foot anyway since it is so responsive.
Since you only want 1 setting, save the $$$ and get the HKS unit.
