float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Dec 21, 2006 5:09 am
Rico nailed it. This is exactly what I did. Go down to the hardware store and get a 1/8NPTx1/4barbed brass fitting. Also buy a 1/8NPT drill and tap. Pull off your turbo outlet pipe, drill and tap a hole in it somewhere on the side, put some RTV or Teflon on the threads, and then thread the fitting into your opening hand tight plus a 1/4 turn. Clean out all of the aluminum bit, and bolt it back onto the turbo. Now you can hook a vac like up to this nipple, tie in the MBC, and then connect the other side of the MBC outlet to the wastegate actuator. Now you're all set!
