kapower06 »
https://forums.nicoclub.com/kapower06-u18983.html
Wed Jul 19, 2006 9:46 am
Lately I have been getting a cut-out issue and could not put my finger exactly on it. So I trouble shooted, pluged BOV port on ARC smic, still cut-out, sprayed entire engine with wd-40 to check for vacuum leaks, nothing. Then I tried one last thing, I removed the MBC (Manual Boost Controller for the noobs). Viola fixed all the rough idle, low (14-16 in. of vacuum), hesitation, and bucking that I had previously experienced. I believe its cause I was using a bleeder type mbc. It let out just enough air to cause the ECU to dump fuel and cut-out.
The purpouse of this thread is to discuss the different types of boost controllers everyone is running along with how the install went, settings, and overall performance.
My MBC was a simple home made ball/spring design. it increased spool-up amazingly, no lag at all between shifts compared to just the wastegate. Would boost up to 10psi before i would get the cut-out issue from it bleeding excess boost.
thanks for any and all replys.
