Ok, I'm in the process of installing my Greddy Profec OLED controller and I've run into conflicting information regarding external WG setups as well as some confusion on my part.
The stock setup has the boost pressure feeding directly to the wastegates, only cutting/bleeding off the supply once the desired pressure is achieved, which allows for boost creep. No thanks.
ex:
http://z32.wikispaces.com/file/view/TT_ ... roller.png
I've also seen setups mainly used for internal WG that involve a MBC/EBC boost stopping the boost from reaching the wastegates until it reaches a certain level, then letting it through(
duty cycles and whatnot) to activate the gates, limiting boost. Makes sense.
However I've seen different diagrams on other forums for this car as well as many others, ex:
http://www.aus300zx.com/forum/showpost. ... ostcount=3
Diagramming a method using the NC port and several tees. From what I've garnered in the last 6 hours of research, this is the superior method for external WG's, as well as the method described in the Greddy manual. Why is it? Couldn't tell you. This is where the confusion on my part comes in.
Ok fine, I'll use the second one then. But wait, how does this setup actually work? Based off the diagram, boost pressure is fed to the lower port(
hold open) of the WG, I'm following so far. The boost pressure is also fed to the NC port on the solenoid, then the COM port feeds to the top port(
hold closed) of the WG.
What?
To put it in the simplest term I can based on my(
probably incorrect) understanding, below the boost threshold it feeds only to the side to open the WG and above set boost it feeds equally to both, negating the effect and causes it to work off spring pressure, won't this just mean I will be getting the spring pressure that is in my WG's?
How does this allow higher boost levels? Why is it superior? It seems to allow for unsatisfactory levels of boost creep as well. I must be missing something, otherwise it wouldn't be recommended in the manual.
Hopefully someone with experience with last setup can chime in and correct me, as I'm having a hard time finding a satisfactory answer.
Thanks for your time and answers!
