BoostFab »
https://forums.nicoclub.com/boostfab-u11693.html
Thu May 29, 2008 9:46 pm
if you hear the spring and the ball move inside then there's no load on the spring, therefore it's not holding pressure.
loosen the nut and then turn the knob down until the spring stop moving and you should feel some resistance from the spring.
make sure all the connection are tight and not leaking
also, how are your lines hooked up ?
