red240obsession214 »
https://forums.nicoclub.com/red240obsession214-u99617.html
Mon Jul 27, 2009 12:09 pm
I searched previous posts and couldn't find a solution to the following problem I'm having. I have SR20DET red top in my 89 240sx and about 3 months ago I installed a manual boost controller I purchased off FRsport. I turned the boost all the way down, installed it and then took it for a test drive. It pushed 15 lbs of boost out of the stock T25 and I hear this is bad and it was as it blew the gasket where my turbo meets the manifold, well I fixed the gasket and removed the boost controller. I couldn't figure out why it was pushing so much boost even with it turned all the way down. Well recently I decided to purchase the Turbosmart boost controller thinking there was something wrong with the other one and it did the same thing. Why is it running so much boost even though it's turned all the way down? My connection of vacuum lines from the boost controller is one to the wastegate and the other is tapped into the vacuum line that was originally ran directly to the wastegate. Thanks in advance for any help or suggestions.
