boost controler?>
scottsnissan
Car: 1995 240 sx se
How would i go about installing a manual boost controler.
Import_Ant
it installs in the ID line to the nipple on your wastegate. you should have instructions with it that tells which nipple on the boost controller connects w/ the line to the wastegate and which connects to the line coming from the boost/vacuum source.
scottsnissan
Car: 1995 240 sx se
its being givin to me so no directions included.But what i wasworried about was do i jus tap it into the line from the cold pip to waste gate|?
Luke
A little pic i made a while ago:
Basically cut the vacuum line going to your wastegate on the turbo. Then run the boost controller in-line on that vacuum line.
