boost controler help
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
ok i have an apexi avcr and have it all set up all most.right now so i can drive it i have the solinod turned off and im letting the wastegate contol it like it would fromthe factory. My only questions are do any off yall have the settings for the gear judge?i know how to set it up but ill have to drive through all the gears and all i have is a 3 inch down pipe on and i live 35 min away from the nearest shop so its pretty loud. second i have everything turned off except the boost control and duty cycle part b/c thats all i want but in order for me to adjust the duty cycle at my desired rpm i have to set the highest rpm.right now i have it set at 8000 do i need to take it to 7000 which is read lne b/c thats pretty much when ill let off of it.thanks in advance guys. oh and this is for a rb25det
Modified by leesredgt at 5:40 PM 11/12/2007
leesredgt
any body plz? at least tell me that by me turning of the boost controller and letting the wastegate regulate the boost will be okay?
leesredgt
any body?
Sky80
Car: '92 240sx Fastback
Dude settle down, someone will answer your question soon enough. In the meantime have you searched on like google or anything(nico search, but not only in the RB section)? You dont necessarily need to search for the RB25, Im sure that the AVCR is pretty much universal in how it works on every car.
Sky80
Bam, went to google, typed in:How to setup an AVCRCame up with this:
http://www.rx7.org/Robinette/b...l.htm
Have fun reading! And good luck Also if you do figure it out, a good idea would be to come back to your post here and tell everyone what steps you took to get it to work on the RB25! Or a writeup would be cool too!
leesredgt
ok i have only one question in this write up it says to disconnect the stock boost solnoid,were is it on my rb25det b/c all i got now is a vaccum line running from the source to the solinoid then to the acuator will that still work?
Sky80
Yes, unless you got a front clip, you probably didnt install the factory boost solenoid on the rb25, so how you have it will be fine
