boost control solenoid
XtremeHKS
do i need it?
LoserbabyS13
Car: 1989 240sx w/ CA18DET and 2003 WRX
I have heard that it is not needed. I am not using it on my setup.
nab911
Car: 93 Nissan 240SX SE
I just took mine off...
USDM_OneVia
Car: Racing
That little valve thingy that mounts up under the ignitor?
First thing to hit the trash when I got my motor.....
Joe
datsunboy
Car: Datsuns
no!don't throw it away!you don't need it.....but if you go have a look at buying a electronically adjustable boost setup from "Link", then you will notice that it is the EXACT same solenoid!and they charge $297NZ for them.
If you don't want to use it for anything...you could at least sell it.
I'm using mine for electronic boost control :)
XtremeHKS
datsunboy wrote:no!don't throw it away!you don't need it.....but if you go have a look at buying a electronically adjustable boost setup from "Link", then you will notice that it is the EXACT same solenoid!and they charge $297NZ for them.
Doesen't it induce F/C?
datsunboy
Car: Datsuns
F/C?
datsunboy
Car: Datsuns
Fuel cut?I've re-programmed my ECU to get rid of fuel cut, and installing a Z32 MAF
XtremeHKS
datsunboy wrote:Fuel cut?I've re-programmed my ECU to get rid of fuel cut, and installing a Z32 MAF
yeah fuel cut
Jezz_s13
Car: Sil80 Track Car
it's not a boost solenoid, the CA didn't have any boost control other than the actuator.It's a hot start solenoid that raises the fuel pressure a bit when hot for starting. You don't need it though, ditched mine eons ago.
datsunboy
Car: Datsuns
exactly what it was....but I re-used it for boost control
float_6969
Jezz has it right. Mine was bad when I got the car and I ditched it. No problems starting when it's hot. It still doesn't like to stay running when it's real cold.
datsunboy
Car: Datsuns
I know that it came factory for the fuel pressure reg, and that you don't need it.but all it is, is a 3 port vacumn solenoid. which can be very easily wired up to control boost electronically
float_6969
Do you have a diagram? Are you using a pressure switch of some sort? It's not that I don't believe you, I just want to understand.
datsunboy
Car: Datsuns
ok, I'll draw one up tomorrow when I have some time.I'm using a boost pressure sensor that I got with my digital goost gauge. but before that I was just going to get a cheap MAP sensor off a Honda ( only because most honda's use a MAP sensor ), which is cheaper than buying after market.then goes to a Op amp ( I think, my electoncis tutor is designing the IC stuff for me ), and a Trim-pot to adjust the boost pressure, using your boost gauge to tell you what boost its set to
datsunboy
Car: Datsuns
the sensor can just be any Pressure transducer that you can find cheap
float_6969
how did you build the amp? I think I understand how it works, but I'm kind of a visual person. If you have/can make a wiring diagram, that would do me wonders. Thanks!
datsunboy
Car: Datsuns
the values of R1,R2, and VR1 depend on the pressure transducer you use.The transducer I am using gives 1.98V out at atsmopheric pressure.
Notchbackca
Car: guess...
if you are putting a Z32 maf on then fuel cut is the least of your worries... boost cut is gonna hit you the second you try to turn the boost up tho(I know it doesn't cut boost, but thats still what its called)
datsunboy
Car: Datsuns
and how how is boost cut removed?
does that pic in my last post work for anyone else?...it worked before, but doesn't work for me now.if it doesn't work, send me an email at... [email protected] and I will send it on
biosehnsucht
you have to copy paste it i nbrowser so it'll show, geocities doesn't like outside linking, then it'll keep showing until you reopen the browser (or it's been awhile).
I tried to resave it and attatch in-thread using the board but stupid 300x300 limit..
Notchbackca
Car: guess...
3690h-369Fhare the address lines for boost limit3F40h-3F4Fhthat is for ttp-max which you might also need to adjust
biosehnsucht
What is TTP Max exactly? I saw that in the adr files for the CA
The boost limit address you give is called 'AF Limit' in the address files from Romedit, I was wondering what that was for.
biosehnsucht
I redid the schematic so it'll fit in the forum builtin image gizmo
Wow, didn't realize how small it was until I posted it, since I was working with it zoomed in lol. Might need to zoom in ... esp. to see the diode there ! hehe
datsunboy wrote:the values of R1,R2, and VR1 depend on the pressure transducer you use.The transducer I am using gives 1.98V out at atsmopheric pressure.
datsunboy
Car: Datsuns
lol....cheers...was just trying to re-do it now, but I only have paint.that black triangle in there is a Op Amp by the way
yes...theres TP limit on my romedit for lines 3690h-369Fhand the TTP max for lines 3F40h-3F4Fh.how do we adjust these to remove boost cut?
