actually without it you only run 5.5psi max where as you see 8psi with the solenoid.Bluefire wrote:screw the solenoid... Just run a hose from the intake manifold to the wastegate and be done with it. All the damn thing does is limit boost low rpm boost and create more unsightly vac hoses.
-Bluefire
I imagine your talking about stock? We got rid of the boost controll solenoid on my friends Z31 and used a MBC and put it up to 10 pounds.... but uh... maybe the RB's are slightly different... I havent found this out for my self on my RB25 as it isnt installed yet, but will be in two weeks...Kamin wrote:actually without it you only run 5.5psi max where as you see 8psi with the solenoid.
