Ender_Zero wrote:....you guys arent listening. he just said that its NOT the stock T25.anyways, i guessing you have an upgraded wastegate? if so, what is it set at?
at least someone reads the thread
. it is not an upgraded wastegate to my knowledge, it's whatever majestic turbo threw on there. most likely a repained stock actuator. when hooked directly to turbo pressure the car hits 7psi.
i've ordered the HKS already, it's worth a shot. if that doesn't cut it i'll dig deeper.
