Boost connections
nismo24T
Car: b-ball, 240sx
Did extensive research and I still can't figure this out:
1) There are 2 nipples on the BOV...where do they connect to?
2) There are two nipples on the Manual Boost Controller...where do they connect to?
3) 1 nipples on wastegate....where does that connect to?
skatanic28
Car: 96 240sx
1. my BOV only has one port on it, and im tee-ing that into the fpr line.
2. the mbc goes inline between the boost source (compressor outlet, hotpipe port, vac line tee) and wastegate.
3. for a tial...the side wg port goes to a boost source, or in this case your mbc.
nissanfanatic
Car: 1992 Nissan 240sx SE
The lower port on your BOV is the lower chamber vent. Leave it open. It is used for cars with large turbos so they can connect a boost source to it and avoid flutter. Just leave it alone.
