Boost build up time
elpiar
Car: 1992 KA-T
I've been having many IC piping leaks although I did the hairspray thing. I think I fixed everything now, but wondering why my boost builds up slowly from 0 to about 9 psi and then builds up much quicker at WOT from 9 psi to 15 psi.
Is it normal for boost to build up slower at the beginning and then close to high boost it increases fast?
I also got a ball-spring manual boost controller by Hallman. My tial wastegate is new so I don't think there is an issue on that side.
WDRacing
Yes...this is normal depending on the turbo you have.
DevilMB3017
That's pretty similar to the way my turbo spools. I have a T3/T40E hybrid with a .63 a/r.
It makes sense though when you think about it, as the turbo spools your creating more exhaust gasses, which is what spools the turbo...
elpiar
Car: 1992 KA-T
I got a t3/t04e 50 trim .48 a/r
