boost_boy
240 Trainee
Do you have a CA18DET Wiring Harness? My Engine will need an uncut harness, as it comes with a harness cut at the firewall. I was wondering how much you would charge for a whole harness, converted if possible. I'm very sorry if you do not do this, I have heard about you though, and thought you could help. My AIM is VANssn240sx, and e-mail is [email protected]. Thanks.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i dont see why everyone needs a full harness. you just end up cutting it there anyway so you can extend it, to allow the ecu to sit in the proper place. all the wires are color coded, so it shouldnt be THAT hard..i could be wrong though.
240 Trainee
So I should just be able to wire firewall back from my KA Harness to the Firewall forward CA Harness? Do the colors match?
Nismo1182
Car: Z06
No, you need the whole UNCUT CA harness. The only part you cut is the dash plug, not the ECU part!!!
dareo
Car: 1993 Q45, 1989 240sx
When they cut the harness, its just for simpler removal right? Do they send you the complete cut harness? Could the harness be rejoined, or do they usually not sell the whole cut harness? A few hours of wire solder and tape would heal a cut harness i would think.
boost_boy
Quote »Do you have a CA18DET Wiring Harness? My Engine will need an uncut harness, as it comes with a harness cut at the firewall. I was wondering how much you would charge for a whole harness, converted if possible.[/quote] Unfortunately, that's not my cup of tea! However, if a harness becomes is too hard to find, I could make a pulsar's harness fit a 240 with CA18DET. I also have 2 JWT ecus one for stock 370cc injectors and the other with a 3bar map and 50lb/hr injectors that was once N/A pulsar computers. Finding a complete CA harness is like finding a needle in a haystack in the U>S> because of the scarcity of the motor.
240 Trainee
They will give me an Uncut Harness for an extra 200, is that my best bet?
NeedCAforS13
Car: CA swapped S13 coupe
yep
Sean
NeedCAforS13
dareo wrote:When they cut the harness, its just for simpler removal right? Do they send you the complete cut harness? Could the harness be rejoined, or do they usually not sell the whole cut harness? A few hours of wire solder and tape would heal a cut harness i would think.
and yes its to make it easier (lazy bastards)
no its not the complete cut harness...just the firewall side. i dunno why they don't just give you the complete harness and let you re-connect it yourself? maybe they don't like extra money or something?
Sean
Nismo1182
Car: Z06
My friends SR came that way,, cut harness but with both parts. Now he has to solder both ends together.
boost_boy
Quote »They will give me an Uncut Harness for an extra 200, is that my best bet?[/quote] Like previously stated, Yes! Spend the money and save yourself the headache.
