Boost boy - ARP head studs q's
CA19DET
i asked the new local ARP dealer for the head studs that you posted were the correct ones:
ATP 5.060-1LB (10 peices)APN 12-1 (10 peices)
well ARP tells him that those are not ARP part numbers, they say that their part numbers are 6 digits.
now i was "told" this and have not spoken to ARP directly, are you sure these are the correct numbers and you have used them?
please help me clear this up
CA19DET
i'm thjinking maybe he is asking for that part number in reference to teh CA18 and they are telling him it is wrong or a different number, but i already got the wrong bolts from them already and i want to clear this all up...
float_6969
I thought you had to modify the head/bolt to make them work?
ca18det_boy
ARP should actually have a part # listing. Off the top of my head I don't know what it is, however I do know that they have them. I'll do some checking and get back with everyone.
CA19DET
they have all sorts of part numbers for the CA18 head bolts, and they sent me the wrong ones already, so i just wanted to clear this all up, and hopefully Boost_boy will soon :D
float_6969
Is there something wrong with the stock units or is this just a precaution?
boost_boy
Part #s are APN12-1 (10pcs)(nuts), ATP 5.060-1 LB (bolts) (10pcs), APN-58 (washers) (10pcs). Revised.............
CA19DET
thanks i'll give ema shot
boost_boy
Quote »Is there something wrong with the stock units or is this just a precaution?[/quote] Just a precaution! Big power needs more clamping force on the head and block. The stock bolts would work, but would not be reuseable once you take them loose.
diamondstar36
Car: Cars and sleep
ARPs or some type of stronger head bolt are really needed to prevent the cylinder head from "lifting" because of pressure in the cylinders.
float_6969
Well I realize that, but at what horsepower levels does this become a concern?
diamondstar36
Car: Cars and sleep
About the time the stock headgasket goes. So around 300whp I guess. It probably becomes an issue before that though.
Nismo1182
Car: Z06
boost_boy wrote:Part #s are APN12-1 (10pcs)(nuts), ATP 5.060-1 LB (bolts) (10pcs), APN-58 (washers) (10pcs). Revised.............
So these bolts are a totally diffrent style than the stock ones?
Im guessing these go on the block first, then you place the head on the block, then the washers and nuts?
boost_boy
Quote »So around 300whp I guess.[/quote] If you're tuning with the little magic/pretty blue screen box or others, this could be a possibility. I'm at 400+ with my woman's car and it hasn't even attempted to buckle on a factory stock set-up minus the HKS camshafts, SDS standalone and a set of MSD 50lb/hr squirters. It's all about the fuel and tuning "Point Blank". And yes to all your questions, Kevin...........
float_6969
Dee, that is how I feel about it. I don't think I'm going to mess with mine. I'm just going to buy a new stock set.
