Thanks for the info. I wasn't sure if I had to turn it clockwise or counterclockwise.jr_ss wrote:Eh, I'd do 2 turns at a time... I think I did mine like 5-6 and I'm at 11-12lbs on mine..
Thanks. Will do!S14toRPS13 wrote:I use to use a HKS actuator. Every 2 to 3 turns making the rod shorter equals about 1 psi. It maxes out at about 14 psi. After that the rod will be too short to release any excess boost and you'll get crazy boost creep. For 9 psi, I'd say turn it clockwise about 5 times and then for a drive.
I'm not exactly sure if it was clockwise, but the shorter the rod, the more psi you'll boost.Steady_One_S13 wrote:
