I am thinking this could be an issue with the Active noise control.Jfpq70 wrote:I have a 2014 Q70 which I have been very satisfied with. Of late I have noticed a booming/droning sound when idling in drive ( such as at a stop light) . It goes away when I select neutral or as a soon as I take off. It would seem that the Active noise control should take care of such as noise. I am not sure if it is working or I have an exhaust or engine issue or it is normal. Any thoughts. I will report it to the dealer next trip, but admittedly it is a minor issue. Just looking for perfection...
There is no way to turn off the Active Noise Cancelling without physically disabling the microphones. There are some other Bose software gizmos that be switched on/off but not the ANC.NRGM45 wrote:I know exactly what you mean. The booming sounds more like a really low and really loud bass note at idle. Imagine being in the car with a subwoofer box in the back seat, and you turn up the bass a lot.... I think the engine resonates with the car frame or something at idle. Because I tried turning off the active sound canceling system while it was doing that and the booming didn't go away.
There are two..the one that is supposed to cancel 'booming' noise from the engine is located in the roof near back window over the rear passenger seatIlya wrote:Where is the mic for the ANC in this car?
These? Warning systems AKA LANE DEPARTURE WARNING (LDW), SYSTEM/LANE DEPARTURE PREVENTION (LDP) SYSTEM, BLIND SPOT WARNING (BSW) SYSTEM, BLIND SPOT INTERVENTION (BSI)NRGM45 wrote:So what is the button to turn it off do ? The one at the top right corner from the row of 8 buttons by your left knee ?
Thought that's what 11 is... On mine it has (what I thought) looks like a speaker with a bunch of sound waves going through it. I was under the impression that turns the active noise canceling system on and off. Guess not ?Debonair wrote:These? Warning systems AKA LANE DEPARTURE WARNING (LDW), SYSTEM/LANE DEPARTURE PREVENTION (LDP) SYSTEM, BLIND SPOT WARNING (BSW) SYSTEM, BLIND SPOT INTERVENTION (BSI)NRGM45 wrote:So what is the button to turn it off do ? The one at the top right corner from the row of 8 buttons by your left knee ?
SYSTEM
That might be the lane departure...is it in the top right? If so, then yes, it's lane departure (stops the beeping if you get on the painted road line).NRGM45 wrote:Thought that's what 11 is... On mine it has (what I thought) looks like a speaker with a bunch of sound waves going through it. I was under the impression that turns the active noise canceling system on and off. Guess not ?Debonair wrote:
SYSTEM
I am sorry but the answer from the tech is unacceptable. I do believe it is pointing to an issue with the ANC.Jfpq70 wrote:Just FYI, I went to the dealer yesterday and reported my noise. The tech came out and listened and said it was normal. He told me that at one time the Gs had a similar condition and they replaced a bunch of stuff trying to eliminate the noise with no success. It is just the nature of the car. I will just try to ignore it.
