DJ MF »
https://forums.nicoclub.com/dj-mf-u11511.html
Fri Oct 29, 2004 3:07 pm
So, the work car is a 2004 2.5S special edition- ie. the one with the thousan bucks in extra goodies. Don't know if you guys get this model in the US.
Anyways, in 9 1/2 months, I've racked up 63,000 km...no problems. Last week, brakes warped, need replacement. Tires bald. Need replacement. I'm a little perturbed, but thankful that I don't have to pay for that.
Today? Stall 5 times at 5 different stop lights. Check engine light blinks. Stall, stall, stall. Rough, ragged engine. Bring to garage.
2 hours later.
Informed that the check engine code referred to cylinder #2. Opened her up and discovered the plug has been broken. Apparently the 'space' that's usually there has been violated. Told to bring to Nissan dealer.
2 hours later. Now driving a Tahoe rental.
Nissan dealer closing. Tells me it's one of two things-
a)a recall issue from prior years where the catalytic converter would do the equivalent of a backwash and dump **** into the engine.
b)some screw or something in the valve set in the first cylinder which has been known to get loose...at which point it takes a tour of the engine innards.
Either way, the engine appears to be shot.
Again, happy I ain't paying.
Any other ideas as to what the hell happened?
MF
