bthsburgess wrote:I have been bitten. The evil, snarply, upgrade bug.
Does anything think it's sane to put a T600-4 and T1500-1db on the stock 2008 Altima 2.5 S alternator/battery. I also intend to move up to P3's and possible switch out my Kenwood components/tweets for the higher Rockford Power series from 2008, which are just obscenely loud and sound much better than my Kenwoods. I was also considering Focal.
Any ideas/help would be great!
Thanks
your alternator has the same amperage as the G35's, 115Amps I believe... so no need to upgrade the alternator for your system IMO. However, I would suggest you upgrade the wiring and do a BIG 3 upgrade using 0 gauge wires , which is fairlyu simple to do in the 2.5 engine bay.
Also, you def need to upgrade that factory battery to a kinetik battery! perhaps a Kinetik 1800
Regarding the amps, I'm running two of those amps now, and they are plenty powerful, but only with upgraded power wires and battery!
