Boo boo oil change.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
So I accidentally changed my oil at 2,991 miles instead of around 3,785 miles. :bang
But I'm at least using my Fram Ultra during this 3rd oci to get my money's worth.
Technically I could keep it for 5 oil changes, so I'll see if I'm in the mood to change it at my next oil change.
Now that I'm older with a bad back, I think I'll relax on the filter changes. Don't bust my balls because I did go from 15,000 mile oil changes for over a decade to 3k oil changes. Yeah I think putting clean oil 5 times is better then keeping the same oil through the filter for 20k miles. First time I used my quick valve drain system too. :domo:
Svtrit
I do 5000 miles and a filter each change, as my miles are a mix of city and country miles. I’ve had cars that were 100% highway that had 10k oci’s and went 200k miles.
Warranty is what drives my oil changes. Once that is up, I’ll do 7500 miles or once per year on a full Synthetic oil.
casperfun
The only reason I’m doing the 3785 oci was just because my Blackstone report was perfection with the lowest wear.
I personally felt that my high silicon levels and iron was due to the long oci and it capturing those particles during that extended period. Mind you, I 100% don’t believe any damage is being done whatsoever. Wear included.
I just wanted a change of pace of doing short oci’s now because my ocd really likes that sweet spot where iron, silicon is low and Blackstone saying I had perfect results finally.
Moreover, I have no problem still doing 15-20k oil changes.
If anything, my cvt transmission will blow up before my engine.
Oil is affordable, and rocking the Fram ultras, so why not, ……..short or long oci’s; no problem! :woot:
Return to “Rogue Forum”
