Bondo on my Fascia
All things Altima Coupe.
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
Hey guys so I bought the stillen fascia from another member who had a turbo and cut the support bars......
So the center piece is a little flimsy. Since I just coils on and my car is so low Im worried about hitting things and the front part breaking off.....
My idea is, I have some bondo laying around, should I fill the hollow space on the bottom center with bondo to make it stronger.
So what Im talking about is the area below the license plate?
If this isnt clear let me know and Ill explain it in more detail, but im at work now... lol :chuckle: :chuckle:
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
I dont think that Bondo is going to prevent it from breaking. If you hit that part I would think that it being to able to bend or flex a little without the Bondo might actually prevent it from breaking. If you make it too rigid it might just crack on impact. Either way I think that the Bondo would just shatter and break off rather than support it that much.
My $0.02
lavon_andy
Car: 2010 Nissan Altima Coupe
fender filler and fiberglass
bondo is heavy and gay
DReed86
Im also going to attach a metal bar underneath the fascia but just around the edges to heighten the support. Im def look into the fender filler Thanks :biggrin:
any other suggestions would be great!
elevate
Car: 2009 Super Black Nissa Altima coupe 2.5S
DReed86 wrote:Hey guys so I bought the stillen fascia from another member who had a turbo and cut the support bars......
the second picture....how the f*** is it that low??, i know you got coils but dam, where r did you take that picture a driveway??
DReed86
yeah thats my parents drive way which I wont be going up anymore... lol
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
Glasss would be te way to go on the inside. Bondo will make it very heavy and cause ur s*** to sag even more lol
lavon_andy
sorry it's called Fairing Filler, you can get it from west marine
it's light as all get out
I'd fill it then glass the back for strength, fairing filler by itself doesn't add any strength it's just filler that's easy to sand/paint if you want to smooth it on the back after you fill it
