Bondo Metal Filler vs. Fiberglass
Karateboy88
I recently got a new S14 with a few rust holes.
My questions is, should I be using something like Bondo's metal filler or a fiberglass compound?
Could someone tell me when Fiberglass is the better choice over the Metal Filler?
Thanks in advance
S13Joe
Car: 92 Coupe
Don't patch rust holes.
White Comet
Car: fc, s13 and mazda6, Sierra
cut out rust and weld in a new piece.
Karateboy88
I don't have a welder and I can't afford to go to a shop
All the rust is in aesthetic location- nothing structural.
White Comet wrote:cut out rust and weld in a new piece.
White Comet
unless you cut all the rust out though it'll just keep rusting under the bondo job until it does rust something important. just spray it with a rust inhibitor until you can get it properly fixed.
S13Joe
Car: 92 Coupe
Look up rusted hatch repair DIY. I used the same technique shaving my antennae. Came out ok, still not finished though...
Karateboy88
Do you guys know of a place that sells different 240sx body panels?
If I can can find the sills for sale, it would save some time.
Thanks
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
got any pictures of said rust?
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Just look around locally in your area or talk to friends and see what friends they have. Most people are willing to lend a helping hand to make some easy cash. It sucks you have the rust, but at the same time putting a bandaid on it will only make it look decently temporarily. Another easy thing to do is try to get a cutout of the piece you need from a donor car and then you don't have hardly any metal work to do. Just cut, fit, and weld. Good luck. Also when will we get to see pictures of this new purchase??
1SickSilvia
Car: 1992 Nissan 240sx vert
I work in a body shop, and I would sugest to sand blast the area thats rusty than use a primer/sealer and use some fiberglass to patch it up. Than you can bondo that and prime and paint.
Karateboy88
daconkiftador wrote:got any pictures of said rust?
If I get the car paint, is the Bondo filler screw me over?
CSUPUEBLOTIM
Yikes. I would be scared as to rust hiding anywhere else. Those are in some nasty spots.
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
scrap it. that thing is junk
wackawacka
Truely incredible. Life never ceases to amaze me.
Are those f***ing text books you are using for jack stands?
Chris28
Car: 92 s13 KA-T
wackawacka wrote:Truely incredible. Life never ceases to amaze me.
It's cool, he's using ADVANCED ALGEBRA with his car.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Books as jack stands.....really....???
S13Joe
Car: 92 Coupe
heartofaskyline wrote:scrap it. that thing is junk
Agreed x100000000
That thing is garbage. Not even worth repairing. I'm just wondering what the frame rails look like... oh yeah, let me guess you have a sun roof don't you?
DanThaMan
Car: 1993 240sx
"If I get the car paint, is the Bondo filler screw me over?"I guess If you english text book is holding up your car its kinda hard to learn how to talk huh. If you just bondo that, its gonna rust out next to it. Either cut, grind and weld, or patch and solder that. Even then its just gonna be a matter of time before it catches cancer again. Good luck bro
duffman1278
DanThaMan wrote:"If I get the car paint, is the Bondo filler screw me over?"I guess If you english text book is holding up your car its kinda hard to learn
Looks like you got into more than you expected. Wasn't going to say this but I GUESS i'll post something useful even though you wont take my advice and just go with the cheapest alternative ftl.
WELD SHEET METAL TO THOSE AREAS! Grind them and make it flush, then enjoy your awesomeness. Filling that all up with bondo is fail
PS go read some of those books NOW!
Shabbernigdo
best use of school books ive ever seen.
Karateboy88
duffman1278 wrote:Books as jack stands.....really....???
Are you guys F***** serious? You think the car is going to bust through the books or something?
This is 100% safe.
DirtyGhettoKids wrote:
Agreed x100000000
I do have a sun roof and it works- NO RUST.
Frame rails are 99% rust free too.
I'm already looking for a welder
DanThaMan wrote:"If I get the car paint, is the Bondo filler screw me over?"I guess If you english text book is holding up your car its kinda hard to learn how to talk huh. If you just bondo that, its gonna rust out next to it. Either cut, grind and weld, or patch and solder that. Even then its just gonna be a matter of time before it catches cancer again. Good luck bro
If I get the car PAINTED, will this much Bondo Body Filler ruin the paint job?
I promise never to post again while I'm sleeping.
Any suggestion on where I can find these rocker panels?
Modified by Karateboy88 at 3:00 PM 6/5/2009
S13Joe
Car: 92 Coupe
This is 0% safe.
I LOL at alot of this post. Why the f*** would body filler effect your paint? You know AUTOMOTIVE BODY SHOPS use filler right? You need to cut rocker panels off of another 240SX and weld them on.
Karateboy88
Has anyone ever seen this company?
http://www2.partstrain.com/sto....html
Not sure if these are replacement parts or just rocker "bras"
duffman1278
Billy Bob Throton uses those on his car.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Body filler (bondo) is polyester resin with a filler in it and is VERY brittle. Polyester resin is also the most common resin for fiberglass work. It is all right for auto body paint shops to use filler because it is only used for SMALL things like scratches or small dings. People who use it for anything larger will inevitably get blisters and cracks in their paint because the metal and filler don't move and expand at the same rate. Plus, any real auto body shop uses "evercoat rage" which is a more light weight and reliable filler.I am very knowledgeable on composites (fiberglass,carbon, resins, etc...) Hince the name "FIBRE GUY" Fibre is another way to say fiber.The only PROPER ways to repair heavily rusted metal is to cut it out and weld a new piece in OR to completely replace it. If i were you I would either weld new pieces in or start looking for a shell.If you get a new shell I call dibs on your 5 lug hubs!
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Agreed x100000000
What does having a sunroof have to do with anything??
Karateboy88
Fibre guy wrote:Body filler (bondo) is polyester resin with a filler in it and is VERY brittle. Polyester resin is also the most common resin for fiberglass work. It is all right for auto body paint shops to use filler because it is only used for SMALL things like scratches or small dings. People who use it for anything larger will inevitably get blisters and cracks in their paint because the metal and filler don't move and expand at the same rate. Plus, any real auto body shop uses "evercoat rage" which is a more light weight and reliable filler.I am very knowledgeable on composites (fiberglass,carbon, resins, etc...) Hince the name "FIBRE GUY" Fibre is another way to say fiber.The only PROPER ways to repair heavily rusted metal is to cut it out and weld a new piece in OR to completely replace it. If i were you I would either weld new pieces in or start looking for a shell.If you get a new shell I call dibs on your 5 lug hubs!
Glad to know someone who knows about fibers (fibres).
I do plan on cutting it out and welding new pieces.
You get dibs if you can tell me about the expected quality of QMI rocker panels of if you can find me another source
Modified by Karateboy88 at 10:11 PM 6/5/2009
Warped161
Car: 90 s13 the never ending project
maj Andres wrote:What does having a sunroof have to do with anything??
The drain lines from the sunroof can cause rust along the bottom of the doors.
GreGS15
you are such a loser..
Fibre guy
^No need to bash someone you don't know.
Taking a closer look at those pictures (the one with the wheel hub) even the subframe and under chassis is rusting. That much rust is an issue. I would actually worry about the more structural stuff than the cosmetic bs. Get a grinder, some wire wheels, and some flap discs to completly clean all of the rust of and then paint on some underbody liner or truck liner. I would do that if you want to save it before it really gets bad.
