eddiec »
https://forums.nicoclub.com/eddiec-u12233.html
Fri Nov 12, 2004 5:37 am
if its the studs on the ends that came out. then finish drilling them out and put bolts w/washers and a nut on it.
or if you have a torch and impact gun then get the old studs out. heat up the flange w/the torch and use the impact to tun a bolt the next size bigger in there. heating it up will help make new threads for the bolts to go in.
god luck
