bolt stuck on my exhaust help remove pls
Nissan 350z / Nissan 370z general community discussion forum
my08350z
Car: 350z
i cant get a bolt unscrewed i tryed eveyrthing from wd40 to this otehr weird crap i bouight at kragen theyh said will get out a bolt and this bolt is stuckk jammed and cammed its impossible to get out.. what do u think i should domy zs currently not able 2 be driven cuz my stock exhaust and bolts are on the groud in garage and i cant get this last bolt out in the center dividing my exhaust to the ypipe.. what do i do to un bolt this crap
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
cut the bolt, then drill and tap for a new bolt
dasoupdude
Car: 2005 Nissan 350Z
a) Get a breaker bar, or a cheater.
b) see if you can get an impact wrench
Cesardrgn
Car: Infiniti G20t-EV0
try tapping it with a hammer
R350Zz33
Car: 2008 350z enthusiast
re bolt up every thing and try and loosen that seeing how yo have al the weight on one bolt.
xjmxstac
Car: 2003 nissan 350z track edition
Have you tried applying heat around where it's stuck? It will expand, maybe loosening up the affected area. I have used this method to remove an old o2 sensor from my truck's exhaust manifold. It was the only way to get that sucker out.
This is a common headache for many exhaust parts because they are exposed to extreme temperatures. With daily use, your exhaust components expand and contract (with the absence/presence of heat), causing nuts and bolts to seize. It's always easier to get them out when they're hot.
R350Zz33
pb blaster is your friend
Return to “350z / 370z Discussion”
