CaribMon71 »
https://forums.nicoclub.com/caribmon71-u102991.html
Tue Oct 14, 2008 9:33 am
Thanks! It's partially what I am looking for. I believe that tells me that it is a 5 bolt pattern set around a 114mm diameter. I still need to know the bore of the hub. Then I can find a suitable spacer. As long as those numbers match, they will work.
The only ones I would trust are by H&R Racing or Eibach. I believe they're both German made and are hubcentric. I had the H&R on my Lexus without any issues.
The information I have for Infinity FX35/FX45/G35/I30/J30/M30/M45/Q45 is :Bolt Pattern: 5/114.3, Center Bore: 66.2, Bolt/Stud Type: Stud, Thread Type: 12x1.25, Spacer Type: DRS, Width: 20mm
Can anyone confirm if this is the same for the EX-35???
