Bolt pattern and finish?
kfk256
I know the wheel specs for m35x is 18 X 8 what is the exact bolt pattern? And is the factory aluminum alloy(not chrome) is the same people refer to as hyper silver or smoked finish? I looking to buy one and i run into all these details, don't wanna buy the wrong one.
szh
Car: 2018 Tesla Model 3.
kfk256 wrote:I know the wheel specs for m35x is 18 X 8 what is the exact bolt pattern? And is the factory aluminum alloy(not chrome) is the same people refer to as hyper silver or smoked finish? I looking to buy one and i run into all these details, don't wanna buy the wrong one.
The wheel specifications are in our Basic Spec sticky thread at the top of the forum. The bolt pattern is standard on the 5-bolt Infiniti cars (not the QX56, though, as I recall).
Also, you should make sure to get the correct offset and hub bore (Nissan and Infiniti standard for the cars is 66.01mm) too, since the new M uses a different offset from other Infiniti's in the past. The actual offset will depend on the wheel width you want ... get a good place to check the fit with the tires you want!
Z
