Bolt Missing Near Intake Manifold, Oil Filter
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
There is a bolt or something missing underneath the intake manifold, near the oil filter and need whatever it is. Help, pictures, anyone got one?
89'ClubK's
Car: 89' Nissan 240SX
There is a bracket that mounts under the oil filter, that connects the block to the transmission. It is very close to the motor mounts. Could be that.
Kouks
No, my motor is in the car, that extra bracket I dont need, and it's gotta be something special. Big whole near my oil filter. Looks like its threaded.
It comes off the block.
damesta
Knock sensor maybe?? Post some pics.
Kouks
wish I could, I dont have the car in my possession right now, but saw it the other day when I went to look at it, cant remember if I ever had anything there.
<Maybe someone else has the pic and I could point it out.......
bentvalves
Car: 89 Silvia K's
if its directly to the right of the oil filter, then its the oil pressure sending unit.
DjLiquid
Car: 1988 Nissan Pulsar
Lol.. same thing happened to me. I found a bolt sitting in a groove of my intake. It looks like an intake bolt but I'd never know what its for since I swapped so much crap out (including bolts from the original CA18DE engine) I don't know what bolt is what =p
float_6969
dvd
float_6969 wrote:
ding ding ding
davidricardo86
Car: 1992 Nissan 240SX SE
heres from top?
Kouks
i need a pic from the underside. I believe its the OP sending unit. However, when I start it, nothing squirts out. I thought it should if thats what it was. it should have made a mess.
biosehnsucht
Can you point it out here ?
biosehnsucht
or here?
green thing is knock sensor, the whitish /bluish tipped one bottom right of the oil filter mount is the oil pressure sender.
Kouks
Yes thank you so much, I wass just about to try and take a pic, the 90 elbow right on top of the oil filter in that pic. What is that for, I dont have one...
UMS_CA18DET
I believe thats his oil cooler, that one looks aftermarket cause my stock oil cooler looks alot different, mine looks like a moon pie.
biosehnsucht
my oil cooler is from the UK.
Do you mean the elbow in the first pic? that is somehow part of the crankcase ventilation system..
FAST section 118
