Bolt location in rear end of S13
JayArr
Car: 1990 Nissan 240SX Coupe
Hello All
I asked this over in the technical forum but got no response, maybe I should have asked here first.
I pulled the subframe off over a year ago and stored all of the "rear end" bolts together in a box. I've now finished sandblasting and POR15 painting the rear sub, all of the links and the spindles and am re-assembling with poly bushings. (It looks great and should handle fantastic)
While sorting through the bolts I came accross these two that are unique and I can't remember where they go. The one is unique because it has a washer that none of the others have, the other is unique because it has the rounded head where all the others are flat with the stamp.
I've looked all through the manual but it's not specific enough in reagards to bolt length or thread. Can anyone help me out here? I'm hoping that some one else has had this problem or that someone who will be under their rear end this week could have a look. I have to believe that the Nissan engineers made these two bolts different for a specific reason and I want to put them back in the right place.
Thanks
Jeff
