I have some bad news I brought my 2nd hand engine 4 days ago from japan an rb25det was very happy with it, as I was trying to get it running i must of somehow droped a bolt into cyl #1 I never noticed this untill the engine stoped cranking over im guessing I have done some major damage inside there, the engine never started as I had the fuel going in the wrong way the hole time so it was just cranking on the starter I did notice a wierd noise coming from the engine and thought nothing of it but after geting a magnet down the hole and picking out crashed bolt or large screw hard to tell its just mashed metal, thats when i knew.
I am so angry with myself for not seeing this, I only know the basics when it comes to engines and I have no idea how bad the damage is, is it a throw away or is one of the valves stuck open witch is causing the engine to stop at a certen point?
How bad do you guys think it is pistion gone? cyl wall damged? or just a bent valve please tell me its just a valve it took me 2 years to save up for the bigger 25det and 4 days later I have done it in what luck.
what do you guys think i should do give up on it all together? or do you think I have only bent a valve and can just replace the one valve without geting the head machined and what not. money is very tight as I stated before took me 2 years to save $2500 should I give up?
sugestions please.
Thanks guys.
