BrianHarte »
https://forums.nicoclub.com/brianharte-u76041.html
Thu Apr 09, 2009 10:38 am
I did a whole writeup.
I guess when it was "reposted", they only posted the rear section.
anywho, let me try and help right now.
first, do the main hoop, then do the "down" bars to the rear wheel area. The metal base plates go under the car. .Cage - car - plate.
The main hoop will get pretty snug in the right position. Did you take out the tar? left it in? I've done it both ways. S14 - left tar in. S13, stripped it.
after you do that main "4 point" thing, work into the front part.
Do the "a pillar" bars and then do the top bar in front of your head. Please make sure to bolt everything together first, then tighten it all afterwards.
doing it alone sucks.
I put my s14 cage in by myself. it sucks BAD. don't try it.
