Ziggy1621 wrote:Well you may have hosed my idea with the file, but you can get two nuts spun onto the shaft. Then you turn them into themselves and they will lock together in the threads. Then you turn the inner nut counter clockwise. It locks against the outer nut and should turn the shaft.
If you can get one nut on, maybe weld it on. Put it on backwards so you weld the bottom of the nut pointing out. Then put a flare nut wrench on the nut and try to turn it.
This trick comes in handy alot. I used it to get the old idler studs out to replace them with Ramey Z ones, the nuts just have to be locked tight enough together. Welding them is a good idea, I never thought of that.
