mrzabala »
https://forums.nicoclub.com/mrzabala-u41785.html
Fri Jul 07, 2006 2:40 pm
Just finished sealing and adding a new valve cover gasket. I tightened the bolts to 7lbs and waited a whole day to cure. Problem is theirs a little leak in the front and I went to 8lbs on all the bolts. Note that at the front of the valve cover their are 3 bolts(middle front and 2 at the corners) that where already loose threaded. Guess previous owner torqued it down without realizing its an aluminium head. Anyways I used some bolts that fit and fixed the middle and the one to the left with bolts I had in storage. As for the one to the right, it snapped leaving a little more than 1/4" in the hole. I also have a nut at the bottom to hold the bolt down which is now screwed in with the broken piece. Is thier a way to take off the broken piece without having to remove the whole thing(replace the gasket and such)? Thanks for the help Ill try and figure something out while I wait for an answer.
